Threads: 114
City: Sneedville, TN
I looked at the schematic for the 37-630 from the library here, copied the PDF of the service documents. I compared it to the schematic I printed out for the 37-640, which is also from the library here. From what I can see the two tuning sections are IDENTICAL. Most of the part reference numbers are even the same, as if someone did a copy and paste when they made the 640 schematic, more likely a tracing back in those days. Just to be sure, can anyone else verify this as a fact? Do any of the real experts on these models here either know if they are exactly the same, or are their differences I missed? I have pulled the tuning section from the 37-630 chassis I am stripping for parts already, and from all I can see, I can use it instead of the NASTY one. It is MUCH cleaner underneath, and will be a much easier job to rebuild, with a much better chance of success.
In other news, this tuning section also had a thick felt washer around the tuning shaft, one in MUCH better condition, so I now have an answer to that question, and a good felt washer to use when I reassemble the tuning section.
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 3297 online users. [Complete List] » 1 Member(s) | 3296 Guest(s)
