37-620 Mystery Part - Value?
Leave it alone, since a wire-wound resistor rarely will change in value.
That color code is for a 1/2W. 200 ohm part. If it is original to the set, then leave it.
Philco liked flexible resistors, but did not use them long in production.
See my site in the Parts Section for more info on the two physical types Philco used.
http://www.philcorepairbench.com/flexrest.htm
By the way, your Model 37-620 had many production and code version changes published.
One of the Production Changes addresses the resistor value discrepancy you found. 200 ohms is correct.
Chuck
37-620 Mystery Part - Value? - by davemc - 01-23-2011, 05:37 PM
Re: 37-620 Mystery Part - Value? - by Chuck Schwark - 01-23-2011, 05:46 PM
Re: 37-620 Mystery Part - Value? - by Ron Ramirez - 01-23-2011, 10:01 PM
Re: 37-620 Mystery Part - Value? - by davemc - 01-24-2011, 02:36 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7423 online users. [Complete List]
» 2 Member(s) | 7421 Guest(s)
