PT-28 Question.
Hi Rob
It was introduced in June 1939 as a 1940 model, and remained in the Philco lineup through the 1941 season.
http://www.philcoradio.com/gallery/1940c.htm#s
PT-28 Question. - by Olden Broak - 04-08-2011, 06:53 PM
Re: PT-28 Question. - by Ron Ramirez - 04-08-2011, 07:50 PM
Re: PT-28 Question. - by Olden Broak - 04-08-2011, 08:32 PM
Eico 232 VTVM Schematic
There are currently 8774 online users. [Complete List]
» 2 Member(s) | 8772 Guest(s)
