46-1226 grille cloth removeal
can anyone tell me how to remove grille cloth that's in good condition with out damaging it... I'm getting ready to refinish cab and i am worried about getting finish on it ,,it looks like it is riveted on
thank,,,john
never mind i found out their tacks
46-1226 grille cloth removeal - by jstaf40 - 01-23-2011, 09:30 PM
There are currently 6139 online users. [Complete List]
» 1 Member(s) | 6138 Guest(s)
