Philco 570 Gramps Clock
So Sunday I cut the rolled part of the bottom off the Sprague electrolytics.
Taking out the threaded part was easy: I grabbed the rubber ring with large pliers and it just came out without much sweat.
I broke off the aluminum threaded rod: there is no way to solder to it and then it is aluminum.
I gave the shells vinegar bath that dissolved all dry salt deposits.
Then I chipped off dry rubber off of the threaded plugs.
Here's what I got now:
As you could see, I use screws and ring terminals to fashion the contact. The plugs are intact and will be glued back in the shells.
I will route a small groove in them to put the negative wire through and will solder it to the shells. I need to think of how I will make the shell to contact the ring on the chassis, ma6be make a small receptacle cup from another old cap.
Philco 570 Gramps Clock - by morzh - 02-01-2020, 10:21 PM
RE: Philco 570 Gramps Clock - by morzh - 02-01-2020, 10:27 PM
RE: Philco 570 Gramps Clock - by morzh - 02-02-2020, 09:36 PM
RE: Philco 570 Gramps Clock - by morzh - 02-09-2020, 09:34 PM
RE: Philco 570 Gramps Clock - by Radioroslyn - 02-09-2020, 10:41 PM
RE: Philco 570 Gramps Clock - by morzh - 02-09-2020, 11:22 PM
RE: Philco 570 Gramps Clock - by Steve Davis - 02-10-2020, 10:14 PM
RE: Philco 570 Gramps Clock - by morzh - 02-10-2020, 10:44 PM
RE: Philco 570 Gramps Clock - by Mike L - 02-13-2020, 04:08 PM
RE: Philco 570 Gramps Clock - by morzh - 02-13-2020, 05:10 PM
RE: Philco 570 Gramps Clock - by morzh - 02-19-2020, 09:36 PM
RE: Philco 570 Gramps Clock - by rfeenstra - 02-19-2020, 09:50 PM
RE: Philco 570 Gramps Clock - by morzh - 03-01-2020, 09:31 PM
RE: Philco 570 Gramps Clock - by morzh - 03-01-2020, 09:40 PM
RE: Philco 570 Gramps Clock - by Brad Winder - 03-05-2020, 10:51 AM
RE: Philco 570 Gramps Clock - by morzh - 03-05-2020, 10:19 PM
RE: Philco 570 Gramps Clock - by KCMike - 03-05-2020, 10:24 PM
RE: Philco 570 Gramps Clock - by morzh - 03-08-2020, 08:50 PM
RE: Philco 570 Gramps Clock - by morzh - 03-12-2020, 07:14 AM
RE: Philco 570 Gramps Clock - by Eliot Ness - 03-12-2020, 12:01 PM
RE: Philco 570 Gramps Clock - by morzh - 03-12-2020, 04:12 PM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 03-12-2020, 08:04 PM
RE: Philco 570 Gramps Clock - by morzh - 03-12-2020, 10:58 PM
RE: Philco 570 Gramps Clock - by morzh - 03-15-2020, 10:20 PM
RE: Philco 570 Gramps Clock - by morzh - 03-22-2020, 11:18 PM
RE: Philco 570 Gramps Clock - by morzh - 03-25-2020, 07:08 PM
RE: Philco 570 Gramps Clock - by morzh - 03-26-2020, 10:53 PM
RE: Philco 570 Gramps Clock - by morzh - 03-27-2020, 08:22 PM
RE: Philco 570 Gramps Clock - by morzh - 03-30-2020, 05:53 PM
RE: Philco 570 Gramps Clock - by KCMike - 03-30-2020, 06:11 PM
RE: Philco 570 Gramps Clock - by morzh - 03-30-2020, 06:25 PM
RE: Philco 570 Gramps Clock - by KCMike - 03-30-2020, 08:27 PM
RE: Philco 570 Gramps Clock - by morzh - 03-30-2020, 09:01 PM
RE: Philco 570 Gramps Clock - by morzh - 03-31-2020, 09:17 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-01-2020, 01:00 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 01:14 PM
RE: Philco 570 Gramps Clock - by KCMike - 04-01-2020, 01:39 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 01:45 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-01-2020, 02:42 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 04:03 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 04:05 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-01-2020, 04:28 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 06:24 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 07:10 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-01-2020, 08:56 PM
RE: Philco 570 Gramps Clock - by morzh - 04-01-2020, 09:21 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-01-2020, 10:50 PM
RE: Philco 570 Gramps Clock - by John Bartley - 04-02-2020, 08:44 AM
RE: Philco 570 Gramps Clock - by morzh - 04-03-2020, 05:05 PM
RE: Philco 570 Gramps Clock - by morzh - 04-03-2020, 05:12 PM
RE: Philco 570 Gramps Clock - by KCMike - 04-03-2020, 06:49 PM
RE: Philco 570 Gramps Clock - by morzh - 04-03-2020, 07:04 PM
RE: Philco 570 Gramps Clock - by rfeenstra - 04-03-2020, 07:11 PM
RE: Philco 570 Gramps Clock - by morzh - 04-03-2020, 07:43 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-04-2020, 11:37 AM
RE: Philco 570 Gramps Clock - by gregb - 04-04-2020, 11:53 AM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-04-2020, 11:59 AM
RE: Philco 570 Gramps Clock - by KCMike - 04-04-2020, 12:03 PM
RE: Philco 570 Gramps Clock - by gregb - 04-04-2020, 03:42 PM
RE: Philco 570 Gramps Clock - by morzh - 04-04-2020, 04:25 PM
RE: Philco 570 Gramps Clock - by gregb - 04-04-2020, 07:04 PM
RE: Philco 570 Gramps Clock - by RodB - 04-04-2020, 07:21 PM
RE: Philco 570 Gramps Clock - by morzh - 04-04-2020, 07:28 PM
RE: Philco 570 Gramps Clock - by morzh - 04-06-2020, 07:12 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-07-2020, 01:03 PM
RE: Philco 570 Gramps Clock - by morzh - 04-07-2020, 02:29 PM
RE: Philco 570 Gramps Clock - by morzh - 04-07-2020, 03:12 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-07-2020, 05:07 PM
RE: Philco 570 Gramps Clock - by morzh - 04-07-2020, 05:20 PM
RE: Philco 570 Gramps Clock - by morzh - 04-07-2020, 08:41 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-08-2020, 09:43 AM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 10:33 AM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-08-2020, 12:38 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 01:14 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 01:22 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-08-2020, 01:23 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 01:45 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 03:31 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 05:27 PM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-08-2020, 05:51 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 09:59 PM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-08-2020, 10:13 PM
RE: Philco 570 Gramps Clock - by morzh - 04-08-2020, 10:38 PM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-09-2020, 07:16 AM
RE: Philco 570 Gramps Clock - by morzh - 04-09-2020, 08:20 AM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-09-2020, 01:55 PM
RE: Philco 570 Gramps Clock - by morzh - 04-09-2020, 03:07 PM
RE: Philco 570 Gramps Clock - by morzh - 04-09-2020, 10:08 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-10-2020, 02:13 PM
RE: Philco 570 Gramps Clock - by morzh - 04-10-2020, 03:32 PM
RE: Philco 570 Gramps Clock - by morzh - 04-11-2020, 03:50 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-12-2020, 11:08 AM
RE: Philco 570 Gramps Clock - by morzh - 04-12-2020, 11:58 AM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-12-2020, 12:29 PM
RE: Philco 570 Gramps Clock - by morzh - 04-12-2020, 01:02 PM
RE: Philco 570 Gramps Clock - by RodB - 04-12-2020, 02:27 PM
RE: Philco 570 Gramps Clock - by morzh - 04-12-2020, 02:53 PM
RE: Philco 570 Gramps Clock - by RodB - 04-12-2020, 09:28 PM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-12-2020, 10:38 PM
RE: Philco 570 Gramps Clock - by morzh - 04-12-2020, 10:50 PM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-13-2020, 07:29 AM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-13-2020, 10:46 AM
RE: Philco 570 Gramps Clock - by morzh - 04-13-2020, 10:58 AM
RE: Philco 570 Gramps Clock - by Ron Ramirez - 04-13-2020, 12:28 PM
RE: Philco 570 Gramps Clock - by Mike L - 04-14-2020, 07:43 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 04-15-2020, 01:45 PM
RE: Philco 570 Gramps Clock - by RodB - 04-15-2020, 02:02 PM
RE: Philco 570 Gramps Clock - by morzh - 04-15-2020, 02:10 PM
RE: Philco 570 Gramps Clock - by Mike L - 04-16-2020, 11:27 AM
RE: Philco 570 Gramps Clock - by Mike L - 04-16-2020, 11:39 AM
RE: Philco 570 Gramps Clock - by morzh - 04-16-2020, 12:04 PM
RE: Philco 570 Gramps Clock - by WyTex - 04-16-2020, 03:23 PM
RE: Philco 570 Gramps Clock - by morzh - 04-22-2020, 03:23 PM
RE: Philco 570 Gramps Clock - by morzh - 05-02-2020, 11:50 PM
RE: Philco 570 Gramps Clock - by morzh - 05-11-2020, 12:57 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 04:19 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 06:00 PM
RE: Philco 570 Gramps Clock - by rfeenstra - 05-12-2020, 06:12 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 06:35 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 06:41 PM
RE: Philco 570 Gramps Clock - by rfeenstra - 05-12-2020, 07:00 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 07:20 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 05-12-2020, 07:52 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 07:58 PM
RE: Philco 570 Gramps Clock - by Eliot Ness - 05-12-2020, 08:07 PM
RE: Philco 570 Gramps Clock - by morzh - 05-12-2020, 08:58 PM
RE: Philco 570 Gramps Clock - by morzh - 05-13-2020, 10:54 AM
RE: Philco 570 Gramps Clock - by Eliot Ness - 05-13-2020, 12:14 PM
RE: Philco 570 Gramps Clock - by morzh - 05-20-2020, 12:05 PM
RE: Philco 570 Gramps Clock - by morzh - 06-13-2020, 09:05 PM
Users browsing this thread: 42 Guest(s)
Philco 49-1040
Philco 49-1040
