Stromberg Carlson AWP-8 transoceanic radio
Newest member of the family. Real clean, and sounds great.  The temp gauge and barometer still work, too.
[Image: https://i.imgur.com/mbMoWGj.jpg?1]
[Image: https://i.imgur.com/Ib6EbJE.jpg?1]
Stromberg Carlson AWP-8 transoceanic radio - by rdnzl - 02-22-2020, 06:57 PM
