Fairbanks Morse model 56
Don't think I've ever seen a metal standard based tube, only on the self centering tubes (octals). Pin 1 is always the heater. Have seen some tubes that have had a sprayed on coating but I don't remember if it has any connection to anything.
Fairbanks Morse model 56 - by Stall-U-Rated - 11-19-2019, 01:51 AM
RE: Fairbanks Morse model 56 - by Radioroslyn - 11-19-2019, 10:30 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-19-2019, 06:38 PM
RE: Fairbanks Morse model 56 - by Radioroslyn - 11-19-2019, 09:15 PM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-21-2019, 01:46 AM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-21-2019, 02:27 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-21-2019, 11:48 PM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-22-2019, 01:06 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-22-2019, 02:15 AM
RE: Fairbanks Morse model 56 - by Steve Davis - 11-22-2019, 07:46 AM
RE: Fairbanks Morse model 56 - by Eliot Ness - 11-22-2019, 11:31 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 11-24-2019, 01:54 AM
RE: Fairbanks Morse model 56 - by Steve Davis - 11-24-2019, 12:31 PM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 12-05-2019, 10:00 PM
RE: Fairbanks Morse model 56 - by mikethedruid - 02-23-2020, 01:23 AM
RE: Fairbanks Morse model 56 - by Radioroslyn - 02-23-2020, 01:59 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 02-23-2020, 02:06 AM
RE: Fairbanks Morse model 56 - by Stall-U-Rated - 02-27-2020, 12:01 AM
Philco 91 Tuning Condenser
