If You Need To Learn About Radio Repair..
#60
Fully agree.  Took the same NRI course my last year in high school and first year working, circa 1977-1979.  Later after finishing about 75% of it I started in the EET program at local community college.  I already knew how to do AC phase calculations and polar vector calculations.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
RE: If You Need To Learn About Radio Repair.. - by PhilcoMike - 02-24-2020, 03:46 PM
Eico 232 VTVM Schematic
There are currently 9608 online users. [Complete List]
» 1 Member(s) | 9607 Guest(s)
