Kolster Rejectostat?
I have a Kolster Brandes KB530 and its case also has a similar inscription.  This is a battery regenerator
Kolster Rejectostat? - by Jayce - 02-25-2020, 04:15 PM
RE: Kolster Rejectostat? - by RadioSvit - 02-25-2020, 04:47 PM
RE: Kolster Rejectostat? - by EdHolland - 03-25-2020, 07:54 PM
RE: Kolster Rejectostat? - by Jayce - 03-26-2020, 04:50 PM
Philco 91 Tuning Condenser
There are currently 8911 online users. [Complete List]
» 2 Member(s) | 8909 Guest(s)
