Espey AM/FM Tube Radio Identification
Sure looks like an Epsey model 100 from '52.
RE: Espey AM/FM Tube Radio Identification - by Radioroslyn - 02-27-2020, 05:17 PM
Philco 91 Tuning Condenser
