Mystery AVC issue on 38-9
The AVC voltage is not the problem, it is a response to the problem. Something in the front end or the IF is causing the signal to drop, the AVC is trying to compensate. You might try a can of circuit cooler to locate the problem.
M R Radios   C M Tubes
Mystery AVC issue on 38-9 - by spierce328 - 03-01-2020, 02:23 PM
RE: Mystery AVC issue on 38-9 - by mikethedruid - 03-01-2020, 02:41 PM
RE: Mystery AVC issue on 38-9 - by Steve Davis - 03-01-2020, 02:53 PM
RE: Mystery AVC issue on 38-9 - by spierce328 - 03-01-2020, 05:42 PM
RE: Mystery AVC issue on 38-9 - by spierce328 - 03-01-2020, 05:49 PM
RE: Mystery AVC issue on 38-9 - by radiodale - 03-01-2020, 06:35 PM
RE: Mystery AVC issue on 38-9 - by spierce328 - 03-01-2020, 07:07 PM
RE: Mystery AVC issue on 38-9 - by morzh - 03-01-2020, 09:19 PM
RE: Mystery AVC issue on 38-9 - by spierce328 - 03-03-2020, 12:44 AM
