Philco 19 Code 128
Question for anyone (reference tube socket voltage chart above)
2nd Det. (75) Plate Volts-P to K is 250 instead of 150
Output (42) Control Grid Volts-CG to K is 15 instead of 2.2
I've replaces all the Caps, most Resistors, and wonder what would make the CG so high on the 2nd Det.? and in turn, I suppose, the Plate voltage 100 v low on the output?
Philco 19 Code 128 - by Simon Wa3uay - 12-31-2019, 03:51 PM
RE: Philco 19 Code 128 - by Radioroslyn - 12-31-2019, 04:19 PM
RE: Philco 19 Code 128 - by Steve Davis - 12-31-2019, 06:54 PM
RE: Philco 19 Code 128 - by Forrest - 12-31-2019, 08:15 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 01-02-2020, 01:47 PM
RE: Philco 19 Code 128 - by Steve Davis - 01-02-2020, 02:31 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 01-21-2020, 01:27 PM
RE: Philco 19 Code 128 - by Forrest - 01-21-2020, 02:19 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 01-21-2020, 05:24 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 02-16-2020, 03:33 PM
RE: Philco 19 Code 128 - by Radioroslyn - 02-16-2020, 03:56 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 02-18-2020, 01:32 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 03-05-2020, 11:39 AM
RE: Philco 19 Code 128 - by Radioroslyn - 03-05-2020, 04:29 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 03-05-2020, 05:02 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 03-17-2020, 03:41 PM
RE: Philco 19 Code 128 - by Radioroslyn - 03-17-2020, 05:41 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 03-17-2020, 07:57 PM
RE: Philco 19 Code 128 - by Radioroslyn - 03-17-2020, 08:10 PM
RE: Philco 19 Code 128 - by Simon Wa3uay - 03-29-2020, 10:14 AM
RE: Philco 19 Code 128 - by Radioroslyn - 03-29-2020, 10:40 AM
RE: Philco 19 Code 128 - by Simon Wa3uay - 04-13-2020, 01:27 PM
There are currently 3317 online users. [Complete List]
» 1 Member(s) | 3316 Guest(s)
