List of Philco Farm Radios?
I could make you a list, using the charts and lists from the Philco Radio 1928-42 book...
But there were other "farm sets" built/sold, depending on the power system your farm had. You could have had 32 volt "Windcharger" power, or even a 110 volt DC generator (rare). Also there were radios that used a 6 volt car battery, and had a vibrator power supply in them, to produce the high voltages needed.
List of Philco Farm Radios? - by Chris Drumma - 02-27-2020, 09:53 AM
RE: List of Philco Farm Radios? - by klondike98 - 02-27-2020, 11:41 AM
RE: List of Philco Farm Radios? - by Brad Winder - 03-07-2020, 12:35 PM
RE: List of Philco Farm Radios? - by Farm Radio - 07-16-2020, 12:17 AM
RE: List of Philco Farm Radios? - by Scott D - 07-16-2020, 08:09 PM
Philco 91 Tuning Condenser
There are currently 6542 online users. [Complete List]
» 2 Member(s) | 6540 Guest(s)
