37-650 buzzing
Another thing to check for that I forgot to mention: poor ground connections. Philco often connected wires to chassis ground through a riveted connection, and corrosion can build up in the chassis hole where the rivet is. You may not see the corrosion but it is there, making ground connections go intermittent or bad altogether.
By the schematic, you should measure 138 ohms across resistor 58 (between B- and ground). If you are reading 143 ohms (not 0.143 ohm), that is close enough.
You should not read more than 138 (143?) ohms across electrolytic 59...the resistance of resistor 58.
37-650 buzzing - by wil - 01-23-2011, 12:15 PM
Re: 37-650 buzzing - by Ron Ramirez - 01-23-2011, 10:07 PM
Re: 37-650 buzzing - by wil - 01-24-2011, 01:14 PM
Re: 37-650 buzzing - by Ron Ramirez - 01-24-2011, 05:21 PM
Re: 37-650 buzzing - by philcoradio1234 - 01-24-2011, 07:32 PM
Re: 37-650 buzzing - by Ron Ramirez - 01-24-2011, 08:03 PM
Re: 37-650 buzzing - by wil - 01-25-2011, 11:04 AM
Re: 37-650 buzzing - by Ron Ramirez - 01-25-2011, 11:24 AM
Re: 37-650 buzzing - by wil - 01-25-2011, 05:08 PM
Re: 37-650 buzzing - by Ron Ramirez - 01-25-2011, 05:20 PM
Re: 37-650 buzzing - by wil - 01-26-2011, 03:16 PM
Re: 37-650 buzzing - by Ron Ramirez - 01-26-2011, 07:46 PM
Re: 37-650 buzzing - by wil - 01-27-2011, 06:56 PM
Re: 37-650 buzzing - by Ron Ramirez - 01-27-2011, 09:00 PM
Re: 37-650 buzzing - by wil - 02-03-2011, 04:14 PM
Re: 37-650 buzzing - by Ron Ramirez - 02-03-2011, 08:06 PM
Re: 37-650 buzzing - by wil - 02-05-2011, 01:05 PM
Re: 37-650 buzzing - by Ron Ramirez - 02-06-2011, 01:42 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5832 online users. [Complete List]
» 3 Member(s) | 5829 Guest(s)
