Westinghouse tuning issue
http://www.nostalgiaair.org/pagesbymodel...024273.pdf
Measure the dc voltage from the chassis - to pin 5 of the 41 tube +. Should see some - voltage there.
Westinghouse tuning issue - by 45philcodon - 03-15-2020, 05:39 PM
RE: Westinghouse tuning issue - by Radioroslyn - 03-15-2020, 06:36 PM
RE: Westinghouse tuning issue - by 45philcodon - 03-15-2020, 08:01 PM
RE: Westinghouse tuning issue - by Radioroslyn - 03-15-2020, 10:21 PM
RE: Westinghouse tuning issue - by Eliot Ness - 03-16-2020, 01:16 PM
RE: Westinghouse tuning issue - by 45philcodon - 03-16-2020, 05:24 PM
RE: Westinghouse tuning issue - by 45philcodon - 03-16-2020, 05:28 PM
RE: Westinghouse tuning issue - by Eliot Ness - 03-16-2020, 05:55 PM
There are currently 9729 online users. [Complete List]
» 1 Member(s) | 9728 Guest(s)
