Philco 37-670 Question about candohm resistors
Hi Jason - Are your candohm resistors open? Just curious since it sounds like you've done the recap. I generally leave them if they're working.
I used 25W resistors on my 37-2670 (very similar set). They still get pretty warm so be sure to mount them to the chassis - or in my case I used an aluminum sheet to mount them so that I didn't have to drill additional holes in the chassis. I use lithium grease under them to ensure decent heat conduction.
[Image: https://live.staticflickr.com/65535/4966...39c4_c.jpg]
RE: Philco 37-670 Question about candohm resistors - by Nathan Slingerland - 03-16-2020, 11:41 AM
There are currently 4615 online users. [Complete List]
» 1 Member(s) | 4614 Guest(s)
