Help! Philco Model 48-1284
Hello Sammy. About all I can say is I have not run into one phonograph in the old radios that I did not have to do a good bit of work on to get them to play. Sometimes disassembly and thorough lube & cleaning will be all. But usually the cartridge or at least needle is bad, and if it uses one, the idler wheel that turns the platter is shot. Hopefully the motor is good.
Help! Philco Model 48-1284 - by sammy_d - 03-16-2020, 12:01 PM
RE: Help! Philco Model 48-1284 - by KCMike - 03-16-2020, 12:34 PM
91H Code 126 Restore
There are currently 4654 online users. [Complete List]
» 3 Member(s) | 4651 Guest(s)
