NOT 37-650! Philco 088 Signal Generator Question
Looking at my Burgess data, the 026 uses two D cells, and two 5156 batteries, and they are tapped 22.5 volt BC batteries. I'm betting that's the same one I made for someone else's Philco siggy gen.
[No subject] - by Chuck Schwark - 03-04-2006, 09:47 PM
[No subject] - by Robbie Roberts - 03-04-2006, 10:06 PM
[No subject] - by Chuck Schwark - 03-04-2006, 10:38 PM
[No subject] - by Robbie Roberts - 03-05-2006, 02:21 AM
[No subject] - by Chuck Schwark - 03-05-2006, 11:38 AM
[No subject] - by Robbie Roberts - 03-05-2006, 11:42 AM
[No subject] - by batterymaker - 03-05-2006, 11:54 AM
