All wave and High efficiency antennas
Chas,
Thanks for the detail. I know in general about antennas, and the efficiency that comes through resonance. Receive is a bit more forgiving than transmitting, but the principles still hold of course.
I found one article that IIRC showed how one of the designs (not Philco I believe) flattened out the response curve.
The other articles I found indicate that the intention was that the antenna could be placed outside, and the balanced lead-in could approach the house without picking up the near field interference from domestic wiring etc. like a simple long-wire would have done. The designs also helped prevent the radio from conveying wiring noise out to the antenna.
This is indeed something that could be a thread all its own, because the isolation methods using transformers do still work brilliantly, especially in keeping the antenna and house wiring separate.
Cheers
Ed
RE: All wave and High efficiency antennas - by EdHolland - 03-23-2020, 11:49 PM
91H Code 126 Restore
There are currently 5449 online users. [Complete List]
» 1 Member(s) | 5448 Guest(s)
