Lafayette HE-30
Today my order from AES arrived. I replaced the 2 section main filter condenser. The original condenser was 40mfd-40mfd at 300 volts. The new one is 50 mfd-50 mfd at 500 volts. It is a perfect fit using the original clamp, contacts fit exactly the same through the chassis hole. My tubes arrived too as part of the order. I will do a test on it later this evening, when reception is better. I am waiting on a 470 ohm 3 watt resistor to replace a 10 mfd electrolytic with a 1 watt 470 ohm resistor across it attached between chassis and the cathode of the audio output tube to create bias, but it may not be necessary. There are a few other electrolytic condensers in the set, all small values that one now uses poly caps to replace, which I will leave until after I give the set a test, and only replace if there seems to be a problem. They all look fine, no bulges or other signs of a problem. Here are pics of the new condenser installed...
[Image: https://66.media.tumblr.com/a93214783efb...5c4be9.jpg]
[Image: https://66.media.tumblr.com/999cfd5c3fc2...c268bb.jpg]
Lafayette HE-30 - by mikethedruid - 03-20-2020, 01:05 AM
RE: Lafayette HE-30 - by Paul Philco322 - 03-20-2020, 09:27 AM
RE: Lafayette HE-30 - by mikethedruid - 03-20-2020, 12:59 PM
RE: Lafayette HE-30 - by Jake Blake - 03-20-2020, 07:31 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 01:07 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 03:59 PM
RE: Lafayette HE-30 - by EdHolland - 03-25-2020, 07:43 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 11:19 PM
RE: Lafayette HE-30 - by mikethedruid - 03-26-2020, 01:21 AM
RE: Lafayette HE-30 - by mikethedruid - 03-26-2020, 10:17 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 11:22 AM
RE: Lafayette HE-30 - by Paul Philco322 - 03-28-2020, 12:23 PM
RE: Lafayette HE-30 - by Jake Blake - 03-28-2020, 02:22 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 03:01 PM
RE: Lafayette HE-30 - by Jake Blake - 03-28-2020, 03:05 PM
RE: Lafayette HE-30 - by Eliot Ness - 03-28-2020, 04:59 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 07:27 PM
There are currently 10238 online users. [Complete List]
» 2 Member(s) | 10236 Guest(s)
