Lafayette HE-30
Hooray ! I have re-installed the S meter and it is now working as it should. Tomorrow I'll button up the case, and test it out on my outdoor antenna. I may yet tweak the alignment to get it just right. The stations are ever so slightly off on the AM broadcast band, maybe 10 Khz, which may mean the IF has drifted slightly from age. We'll see. I won't do anything if it performs as well as it promises to. I have learned to leave well enough alone.
Lafayette HE-30 - by mikethedruid - 03-20-2020, 01:05 AM
RE: Lafayette HE-30 - by Paul Philco322 - 03-20-2020, 09:27 AM
RE: Lafayette HE-30 - by mikethedruid - 03-20-2020, 12:59 PM
RE: Lafayette HE-30 - by Jake Blake - 03-20-2020, 07:31 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 01:07 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 03:59 PM
RE: Lafayette HE-30 - by EdHolland - 03-25-2020, 07:43 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 11:19 PM
RE: Lafayette HE-30 - by mikethedruid - 03-26-2020, 01:21 AM
RE: Lafayette HE-30 - by mikethedruid - 03-26-2020, 10:17 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 11:22 AM
RE: Lafayette HE-30 - by Paul Philco322 - 03-28-2020, 12:23 PM
RE: Lafayette HE-30 - by Jake Blake - 03-28-2020, 02:22 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 03:01 PM
RE: Lafayette HE-30 - by Jake Blake - 03-28-2020, 03:05 PM
RE: Lafayette HE-30 - by Eliot Ness - 03-28-2020, 04:59 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 07:27 PM
There are currently 10540 online users. [Complete List]
» 2 Member(s) | 10538 Guest(s)
