640x question
Hello and welcome!
The three-section electrolytic has definitely been replaced at some time in the past. Philco did not increase the values of those electrolytics that much; in fact, I just looked through my copy of the Philco "Changes in Models" sheets, and I did not find any change to part (68).
You should replace these three electrolytics, ideally, with two 2.2 uF and one 1 uF. You could replace all three with 2.2 uF, 3.3 uF, or even 4.7 uF, 450 volts. But there is no need to go above that value. 30, 15 or 10 uF in those positions won't hurt the rectifier tube, but would be a waste of money as there is no need to have capacitors that large in those positions.
640x question - by troym - 01-29-2011, 07:53 PM
Re: 640x question - by Ron Ramirez - 01-29-2011, 08:49 PM
Re: 640x question - by radiomikee - 01-30-2011, 02:40 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6289 online users. [Complete List]
» 4 Member(s) | 6285 Guest(s)
AvatarAvatarAvatarAvatar
