Unboxing 2 Forgotten Radios on YouTube
I forgot to turn the variac off, good thing the radio was off, haha
Unboxing 2 Forgotten Radios on YouTube - by Buzz - 03-27-2020, 07:57 PM
RE: Unboxing 2 Forgotten Radios on YouTube - by Buzz - 03-27-2020, 09:23 PM
Philco 91 Tuning Condenser
