Lafayette HE-30
" . . . one must have the "selectivity" control all the way clockwise until it clicks into the AM-CW-SSB position, . . ."
So, let me get this straight.... you're actually increasing selectvity, tuning, then turning it back the other way (counterclockwise), to increase sensitivity to improve frequency response?  . . . is that how it works?   Icon_question Icon_idea
Lafayette HE-30 - by mikethedruid - 03-20-2020, 01:05 AM
RE: Lafayette HE-30 - by Paul Philco322 - 03-20-2020, 09:27 AM
RE: Lafayette HE-30 - by mikethedruid - 03-20-2020, 12:59 PM
RE: Lafayette HE-30 - by Jake Blake - 03-20-2020, 07:31 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 01:07 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 03:59 PM
RE: Lafayette HE-30 - by EdHolland - 03-25-2020, 07:43 PM
RE: Lafayette HE-30 - by mikethedruid - 03-25-2020, 11:19 PM
RE: Lafayette HE-30 - by mikethedruid - 03-26-2020, 01:21 AM
RE: Lafayette HE-30 - by mikethedruid - 03-26-2020, 10:17 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 11:22 AM
RE: Lafayette HE-30 - by Paul Philco322 - 03-28-2020, 12:23 PM
RE: Lafayette HE-30 - by Jake Blake - 03-28-2020, 02:22 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 03:01 PM
RE: Lafayette HE-30 - by Jake Blake - 03-28-2020, 03:05 PM
RE: Lafayette HE-30 - by Eliot Ness - 03-28-2020, 04:59 PM
RE: Lafayette HE-30 - by mikethedruid - 03-28-2020, 07:27 PM
There are currently 8550 online users. [Complete List]
» 1 Member(s) | 8549 Guest(s)
