Next project: Western Air Patrol
Loctite brand Naval Jelly.
It's the basic pink gooey stuff that uses phosphoric acid as the active ingredient. I've got about 1/2 the top area and most of the back looking more respectable now, and it will come up OK.
I also stripped the top of the cabinet, and started restaining it to reproduce an interpretation of the original colour. The rest will be left, as there are decals I do not want to disturb. Cleaning has done much to return a presentable appearance.
On the electronics, I'm just looking things over. Many of the paper caps don't appear to have values marked, but have manufacturer codes instead. This will take a bit of detective work. One idea I have is to bake to remove moisture. I tried this on an old, really leaky cap from my Philco restoration. While it won't return safe high voltage performance, leakage at low voltage reduced greatly - enough that the capacitance meter returned a value close to nominal.
More pics later.
Cheers
Ed
Next project: Western Air Patrol - by EdHolland - 01-18-2018, 05:28 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 05:31 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 11:55 PM
RE: Next project: Western Air Patrol - by Arran - 01-19-2018, 12:52 AM
RE: Next project: Western Air Patrol - by SteveG - 01-19-2018, 07:14 PM
RE: Next project: Western Air Patrol - by Arran - 01-23-2018, 01:11 AM
RE: Next project: Western Air Patrol - by David - 01-25-2018, 09:48 PM
RE: Next project: Western Air Patrol - by EdHolland - 03-29-2020, 05:11 PM
RE: Next project: Western Air Patrol - by KCMike - 04-05-2020, 04:56 PM
RE: Next project: Western Air Patrol - by RodB - 04-20-2020, 08:51 PM
RE: Next project: Western Air Patrol - by RodB - 04-21-2020, 09:54 AM
RE: Next project: Western Air Patrol - by 462ron - 04-24-2020, 07:48 AM
RE: Next project: Western Air Patrol - by 462ron - 04-26-2020, 08:47 AM
Philco 91 Tuning Condenser
