Scott SLRM
Notice the power plug is 3 prong polarized, grounding the chassis to house ground.  I assume your ac power cord is 3 wire.  If so, you do not have a hot chassis.  I listen to mine regularly without an isolation transformer.  Meter measurements of the chassis confirm that the chassis at ground potential.
Edit: I tooka couple of measurements on mine with the AC ground pin floating. No AC on the chassis but there was some DC. As I watched, the DC slowly came down. I grounded the chassis for a second and the chassis then remained at near 0 volts. Reception was actually quieter with the ground attached.
Scott SLRM - by mikethedruid - 04-01-2020, 03:55 PM
RE: Scott SLRM - by Too poor to retire - 04-01-2020, 04:05 PM
RE: Scott SLRM - by mikethedruid - 04-01-2020, 04:32 PM
RE: Scott SLRM - by rfeenstra - 04-01-2020, 04:33 PM
RE: Scott SLRM - by Eliot Ness - 04-01-2020, 04:41 PM
RE: Scott SLRM - by rfeenstra - 04-01-2020, 05:04 PM
RE: Scott SLRM - by Too poor to retire - 04-01-2020, 05:20 PM
RE: Scott SLRM - by mikethedruid - 04-01-2020, 05:31 PM
Philco 91 Tuning Condenser
There are currently 4116 online users. [Complete List]
» 1 Member(s) | 4115 Guest(s)
