Scott SLRM
I think rfeenstra answered your question, but below is a link to his restoration thread you might find helpful:
https://www.philcoradio.com/phorum/showt...?tid=19823
Scott SLRM - by mikethedruid - 04-01-2020, 03:55 PM
RE: Scott SLRM - by Too poor to retire - 04-01-2020, 04:05 PM
RE: Scott SLRM - by mikethedruid - 04-01-2020, 04:32 PM
RE: Scott SLRM - by rfeenstra - 04-01-2020, 04:33 PM
RE: Scott SLRM - by Eliot Ness - 04-01-2020, 04:41 PM
RE: Scott SLRM - by rfeenstra - 04-01-2020, 05:04 PM
RE: Scott SLRM - by Too poor to retire - 04-01-2020, 05:20 PM
RE: Scott SLRM - by mikethedruid - 04-01-2020, 05:31 PM
Philco 91 Tuning Condenser
There are currently 5937 online users. [Complete List]
» 2 Member(s) | 5935 Guest(s)
