  • 1 Vote(s) - 1 Average
1953 Sentinel 344 restore on YouTube
Nice work and entertaining. Like the antenna job and and the pointer, resourceful. Nice to have something fun and informative to watch.  Icon_clap
1953 Sentinel 344 restore on YouTube - by Buzz - 04-07-2020, 07:19 PM
RE: 1953 Sentinel 344 restore on YouTube - by Paul Philco322 - 04-07-2020, 08:06 PM
Philco 91 Tuning Condenser
