Philco 38-3 completely redone no reception
Hi, guys
Managed to grab a few minutes last night to check continuity on all the coils on the 38-3, and there are no broken wires.
Out of curiousity, I touched one probe to the chassis and the other probe to the antenna terminal marked RED. That's where I have my longwire antenna attached. The other two terminals on that piece of fibre board are marked BLACK and GND, and are jumpered together and grounded to chassis. I recorded continuity between the RED terminal and the chassis. Should that happen? Thanks!
RE: Philco 38-33 completely redone no reception - by DuMont - 04-08-2020, 10:22 AM
There are currently 3533 online users. [Complete List]
» 1 Member(s) | 3532 Guest(s)
