40-180 phono plug
So using the schematic, and feeding in a stereo source, only one channel will be heard? That means you could only feed in a monaural source?
If I wanted to combine both channels, is their a way to do that and still eliminate a switch?
40-180 phono plug - by Patrick - 04-07-2020, 09:27 PM
RE: 40-180 phono plug - by radiodale - 04-07-2020, 10:01 PM
RE: 40-180 phono plug - by Ron Ramirez - 04-07-2020, 10:02 PM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 06:33 AM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 06:46 AM
RE: 40-180 phono plug - by Ron Ramirez - 04-08-2020, 07:56 AM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 09:20 AM
RE: 40-180 phono plug - by radiodale - 04-08-2020, 09:28 AM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 12:46 PM
RE: 40-180 phono plug - by radiodale - 04-08-2020, 03:41 PM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 03:56 PM
RE: 40-180 phono plug - by radiodale - 04-08-2020, 04:02 PM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 04:06 PM
RE: 40-180 phono plug - by Steve Davis - 04-08-2020, 04:58 PM
RE: 40-180 phono plug - by Ron Ramirez - 04-08-2020, 05:18 PM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 05:23 PM
RE: 40-180 phono plug - by Ron Ramirez - 04-08-2020, 05:46 PM
RE: 40-180 phono plug - by Patrick - 04-08-2020, 05:54 PM
RE: 40-180 phono plug - by Ron Ramirez - 04-08-2020, 05:55 PM
There are currently 3918 online users. [Complete List]
» 2 Member(s) | 3916 Guest(s)
