46-1226 code 122 no am or shortwave good phono,, i fixed it
Well - voltage on the grid is a good thing but to double check the osc set the bandswitch for the bc band. Tune the dial to 1000kc. Use a transistor radio near the 7af7. Tune it to 1000kc + the IF frequency 455kc. 1455kc. If the LO is running you will hear a loud hum in the transistor radio. If the tuning isn't dead on on the Philco you may need to adjust it's frequency bit to hear the LO (local oscillator)
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5297 online users. [Complete List]
» 3 Member(s) | 5294 Guest(s)
