IF Can Capacitor value (SMD)
Hey guy's I have a Admiral 5R11 with a 5R1 chassis the print is here.
http://www.nostalgiaair.org/pagesbymodel...000103.pdf
It had SMD so I have disassembled and removed the mica and trimmed the paddled so they don't touch.
 the original cans have been replaced ( probably smd), the resistance of the new cans is the same at 24 ohms per coil 455kc
There is silver mica disease so my problem is this. What value for the caps? The print shows nothing, is there any way to ball park the PF value or do I just start subbing values, if so what is a starting point 130pf?
Thanks Eric
IF Can Capacitor value (SMD) - by Eric - 04-10-2020, 02:57 PM
RE: IF Can Capacitor value (SMD) - by Tubeglow20 - 04-19-2020, 08:43 PM
