Early 16B tombstone
So Have been busy sanding and stripping the cabinet. I think the cabinet had been stained whatever was on the didn't really come off much but was able to give it a rub down in mek and then sand. The edge of the repair piece need a little adjustment, the edge had a bit of an overhang but some 60G paper and a sanding block made quick work of that and it's difficult to tell from the other side. Resanded w/320G to sand out fine scratches. Will spray the lt side and top tonight and glue sometime later this week.
Was wondering what grille cloth to use? It has chevron patterned cloth in it now but not sure if it's correct.
Early 16B tombstone - by Radioroslyn - 05-16-2019, 03:14 PM
RE: Early 16B tombstone - by Ron Ramirez - 05-16-2019, 04:32 PM
RE: Early 16B tombstone - by Radioroslyn - 05-16-2019, 07:08 PM
RE: Early 16B tombstone - by Radioroslyn - 06-12-2019, 12:29 PM
RE: Early 16B tombstone - by Ron Ramirez - 06-12-2019, 01:59 PM
RE: Early 16B tombstone - by morzh - 06-12-2019, 02:18 PM
RE: Early 16B tombstone - by klondike98 - 06-12-2019, 11:56 PM
RE: Early 16B tombstone - by Nathan Slingerland - 06-13-2019, 10:44 AM
RE: Early 16B tombstone - by morzh - 06-13-2019, 11:27 AM
RE: Early 16B tombstone - by Radioroslyn - 06-13-2019, 01:53 PM
RE: Early 16B tombstone - by Radioroslyn - 08-16-2019, 05:29 PM
RE: Early 16B tombstone - by NostalgiaRadioTime - 08-17-2019, 12:12 AM
RE: Early 16B tombstone - by Radioroslyn - 08-17-2019, 09:59 AM
RE: Early 16B tombstone - by NostalgiaRadioTime - 08-17-2019, 11:43 PM
RE: Early 16B tombstone - by Radioroslyn - 04-08-2020, 03:51 PM
RE: Early 16B tombstone - by Radioroslyn - 04-11-2020, 08:40 PM
RE: Early 16B tombstone - by Radioroslyn - 04-15-2020, 04:02 PM
RE: Early 16B tombstone - by Nathan Slingerland - 04-15-2020, 04:03 PM
RE: Early 16B tombstone - by Radioroslyn - 04-15-2020, 09:31 PM
RE: Early 16B tombstone - by Radioroslyn - 04-17-2020, 04:01 PM
RE: Early 16B tombstone - by morzh - 04-17-2020, 04:44 PM
RE: Early 16B tombstone - by Radioroslyn - 04-19-2020, 08:56 AM
RE: Early 16B tombstone - by Radioroslyn - 05-07-2020, 10:52 AM
RE: Early 16B tombstone - by klondike98 - 05-07-2020, 12:42 PM
RE: Early 16B tombstone - by Radioroslyn - 05-07-2020, 01:39 PM
RE: Early 16B tombstone - by EdHolland - 05-07-2020, 03:21 PM
RE: Early 16B tombstone - by Radioroslyn - 05-07-2020, 04:42 PM
RE: Early 16B tombstone - by EdHolland - 05-07-2020, 09:46 PM
RE: Early 16B tombstone - by Brad Winder - 05-10-2020, 12:45 AM
RE: Early 16B tombstone - by Radioroslyn - 05-10-2020, 09:07 AM
