Philco 46-1201 code 125
Hello from Spain, long time since my last restoration of a philco radio, since we have this confined situation I got some time to do a 46-1201 code 125 that I had stored, the cabinet finish was totally gone cracked, although the wood underneath is ok. The electronics inside looks totally original, the 4x6 speaker cone is well broken so I will have to recone or find a spare, the m7 phonograph is stuck cause of the dry grease so after disassembly is the first thing I am doing now, I can not find any info about the M7 record player adjustments, also after disassembly of the motor and cleaning it I am in doubt about the order of the propeller side washers and clips, anyone have picture of it? I forgot to do a photo (I do of everything but this I forgot) as I recall the order is clip, white paper fiber washer, propeller, metal washer, felt washer, white paper washer and clip??
The mercury switch works but the small grommet that rest on the arm is worn and the grip paint gone, any source for the grommet?
I will post photos of the progress
Philco 46-1201 code 125 - by Jeepeto - 04-13-2020, 05:39 PM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-13-2020, 05:51 PM
RE: Philco 46-1201 code 125 - by falcon123 - 04-13-2020, 08:02 PM
RE: Philco 46-1201 code 125 - by Radioroslyn - 04-13-2020, 09:01 PM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-14-2020, 12:30 AM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-17-2020, 03:30 AM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-17-2020, 03:35 AM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-17-2020, 04:52 AM
RE: Philco 46-1201 code 125 - by falcon123 - 04-17-2020, 05:03 AM
RE: Philco 46-1201 code 125 - by Radioroslyn - 04-17-2020, 07:24 AM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-17-2020, 08:42 AM
RE: Philco 46-1201 code 125 - by Ron Ramirez - 04-17-2020, 01:51 PM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-18-2020, 03:34 AM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-18-2020, 08:15 AM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-20-2020, 09:34 AM
RE: Philco 46-1201 code 125 - by Radioroslyn - 04-20-2020, 09:10 PM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-22-2020, 06:58 AM
RE: Philco 46-1201 code 125 - by Radioroslyn - 04-22-2020, 02:52 PM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-22-2020, 05:20 PM
RE: Philco 46-1201 code 125 - by Jeepeto - 04-26-2020, 03:40 PM
There are currently 4483 online users. [Complete List]
» 2 Member(s) | 4481 Guest(s)
