  • 1 Vote(s) - 3 Average
Corona Boredum
Neato!
 I have a very similar one but mine is a Harold Bell.
Mine is missing one escutcheon... Grrrrrr....
I'll have to make one when I get back to molds this fall.
Great work as usual.
Icon_clap
Corona Boredum - by Phlogiston - 04-14-2020, 02:15 PM
RE: Corona Boredum - by OldRestorer - 04-14-2020, 02:25 PM
RE: Corona Boredum - by Phlogiston - 04-14-2020, 03:52 PM
Philco 91 Tuning Condenser
There are currently 9011 online users. [Complete List]
» 1 Member(s) | 9010 Guest(s)
