Refinishing my 40-180 cabinet
Realistically you can do it either way filler first and then sanding sealer or the other way round but my thinking is this. The filler is very dark and stains the wood if there is no sealer on the wood. That's ok but if the use the sealer first it blocks the filler from staining the wood and just fills the pores (after you wipe it down). This will give you much more contrast between the pours and the areas that are not porous.
Refinishing my 40-180 cabinet - by fwmartin2000 - 04-14-2020, 11:01 PM
RE: Refinishing my 40-180 cabinet - by Radioroslyn - 04-16-2020, 01:28 PM
RE: Refinishing my 40-180 cabinet - by GarySP - 05-25-2020, 08:56 AM
RE: Refinishing my 40-180 cabinet - by klondike98 - 05-27-2020, 07:40 PM
RE: Refinishing my 40-180 cabinet - by PhilcoJohn - 06-03-2020, 07:16 PM
RE: Refinishing my 40-180 cabinet - by KCMike - 06-04-2020, 06:53 PM
RE: Refinishing my 40-180 cabinet - by tbone - 09-18-2020, 06:19 PM
