84b vs 60 speaker
thanks ron. as i looked at the '37 philco parts book i was confused by the small difference between the two. so much so that i figured i'd better ask as i thought i was missing something! it does make me wonder why they bothered making one or the other.
84b vs 60 speaker - by falcon123 - 04-16-2020, 01:41 AM
RE: 84b vs 60 speaker - by Ron Ramirez - 04-16-2020, 09:31 AM
RE: 84b vs 60 speaker - by falcon123 - 04-16-2020, 05:08 PM
RE: 84b vs 60 speaker - by falcon123 - 04-17-2020, 09:14 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
