Zenith Schematics resource like Philcos
I have the set from KE3GK and they are hi resolution scans. Very readable. I usually blow up the schematics and tape together as well. The hi res pdf's are good enough to do that.
RE: Zenith Schematics resource like Philcos - by rfeenstra - 04-16-2020, 07:43 PM
Philco 91 Tuning Condenser
