Signal Generator Help
It will do the job, yes.
However, with these what I used (before settling on an HP) was a counter. I bought a decent BK Precision counter for $25 and every time I set a frequency I first would feed it to counter to set it exactly to what I needed. Then use it to align the radio.
Cumbersom but not too bad.
Otherwise your ST dial could be off quite a bit and your radio will be misaligned.
Recently there was a thread about folks using a cheap front panel counters built in their cheap tube SGs.
Terry might be the initiator of one of them. I think it was in the year of 2019.
This would make it almost as good as an HP.
Signal Generator Help - by captainclock1988 - 04-16-2020, 07:53 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 07:56 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 08:20 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 08:44 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 09:27 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 09:50 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 10:14 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 10:43 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 10:50 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 11:08 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 11:24 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 11:34 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 11:51 PM
RE: Signal Generator Help - by 462ron - 04-17-2020, 08:01 AM
RE: Signal Generator Help - by Eliot Ness - 04-17-2020, 11:00 AM
RE: Signal Generator Help - by captainclock1988 - 04-17-2020, 07:44 PM
RE: Signal Generator Help - by captainclock1988 - 04-21-2020, 02:28 PM
RE: Signal Generator Help - by rfeenstra - 04-21-2020, 03:14 PM
RE: Signal Generator Help - by captainclock1988 - 04-21-2020, 07:45 PM
RE: Signal Generator Help - by 462ron - 04-22-2020, 07:53 AM
RE: Signal Generator Help - by captainclock1988 - 04-22-2020, 09:16 AM
RE: Signal Generator Help - by John Bartley - 04-22-2020, 11:10 AM
RE: Signal Generator Help - by captainclock1988 - 04-22-2020, 11:17 AM
RE: Signal Generator Help - by 462ron - 04-23-2020, 08:37 AM
RE: Signal Generator Help - by 462ron - 04-23-2020, 09:04 AM
RE: Signal Generator Help - by captainclock1988 - 04-23-2020, 12:08 PM
RE: Signal Generator Help - by captainclock1988 - 04-26-2020, 09:15 PM
RE: Signal Generator Help - by 462ron - 04-27-2020, 07:50 AM
RE: Signal Generator Help - by captainclock1988 - 04-27-2020, 04:18 PM
RE: Signal Generator Help - by captainclock1988 - 04-27-2020, 10:21 PM
Eico 232 VTVM Schematic
There are currently 6609 online users. [Complete List]
» 3 Member(s) | 6606 Guest(s)
