Q1791WA - first project!
Would that cap be connected between two of the speakers?? Is the hum present when you select the radio or tape position?
Q1791WA - first project! - by Qbinalex - 08-13-2019, 12:14 AM
RE: Q1791WA - first project! - by morzh - 08-13-2019, 08:37 AM
RE: Q1791WA - first project! - by Qbinalex - 08-13-2019, 09:49 AM
RE: Q1791WA - first project! - by Scott D - 08-18-2019, 10:35 PM
RE: Q1791WA - first project! - by Stall-U-Rated - 08-19-2019, 12:30 AM
RE: Q1791WA - first project! - by Arohn19 - 08-19-2019, 08:39 PM
RE: Q1791WA - first project! - by Arohn19 - 08-19-2019, 08:46 PM
RE: Q1791WA - first project! - by Qbinalex - 08-19-2019, 10:56 PM
RE: Q1791WA - first project! - by mikethedruid - 08-19-2019, 11:08 PM
RE: Q1791WA - first project! - by Jake Blake - 08-20-2019, 07:41 AM
RE: Q1791WA - first project! - by Ron Ramirez - 08-20-2019, 02:05 PM
RE: Q1791WA - first project! - by Qbinalex - 08-20-2019, 03:45 PM
RE: Q1791WA - first project! - by Qbinalex - 04-20-2020, 08:43 PM
RE: Q1791WA - first project! - by Radioroslyn - 04-20-2020, 09:24 PM
RE: Q1791WA - first project! - by Qbinalex - 04-20-2020, 09:44 PM
RE: Q1791WA - first project! - by Radioroslyn - 04-20-2020, 10:15 PM
RE: Q1791WA - first project! - by Qbinalex - 04-20-2020, 10:28 PM
RE: Q1791WA - first project! - by Qbinalex - 05-08-2020, 09:48 PM
Philco 91 Tuning Condenser
