Next project: Western Air Patrol
#54
My thinking is that if a signal of a certain strength at 8 or 9 MHZ can be received in the antenna on band B then a 14 MHZ signal at the same strength should be received on band C (with some variation). If not, then the antenna circuit isn't doing the job. Of course, you probably already know that but it might verify that you're on the right track. I have always figured that antenna transformer design is a science and some radio designers are not scientists. Keep searching. Rod
Next project: Western Air Patrol - by EdHolland - 01-18-2018, 05:28 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 05:31 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 11:55 PM
RE: Next project: Western Air Patrol - by Arran - 01-19-2018, 12:52 AM
RE: Next project: Western Air Patrol - by SteveG - 01-19-2018, 07:14 PM
RE: Next project: Western Air Patrol - by Arran - 01-23-2018, 01:11 AM
RE: Next project: Western Air Patrol - by David - 01-25-2018, 09:48 PM
RE: Next project: Western Air Patrol - by KCMike - 04-05-2020, 04:56 PM
RE: Next project: Western Air Patrol - by RodB - 04-20-2020, 08:51 PM
RE: Next project: Western Air Patrol - by RodB - 04-21-2020, 09:54 AM
RE: Next project: Western Air Patrol - by 462ron - 04-24-2020, 07:48 AM
RE: Next project: Western Air Patrol - by 462ron - 04-26-2020, 08:47 AM
Philco 91 Tuning Condenser
