Next project: Western Air Patrol
Threads: 44
City: Menlo Park
State, Province, Country: CA
Some possible insight today. I didn't get long with the radio, but had a moment to switch on and poke about, literally, touching low voltage signal points in the front end and IF chain. Twice, I was able to surprise the set into a state of improved sensitivity, suggesting that something is either unstable, or there is an intermittent contact.
First thing will be cleaning the switches and valve sockets again, rotor contacts on the tuning cap etc. then another look at some voltages. Helpfully, even though I am schematic-less, valve data sheets give a good idea what to expect, plus example circuits and component values.
Something is slightly amiss, but it is playing hard-to-get. It is times like this where it is good to be doing this as a hobby, rather than for a customer
RE: Next project: Western Air Patrol - by EdHolland - 04-23-2020, 06:20 PM
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
