vacuum tube education needed
YUP, there just #26 tubes. Test them all the same.
Gregb
vacuum tube education needed - by truePhilco - 04-24-2020, 06:15 PM
RE: vacuum tube education needed - by gregb - 04-24-2020, 07:23 PM
RE: vacuum tube education needed - by truePhilco - 04-24-2020, 08:06 PM
RE: vacuum tube education needed - by gregb - 04-24-2020, 08:58 PM
RE: vacuum tube education needed - by Radioroslyn - 05-06-2020, 08:59 PM
Philco 91 Tuning Condenser
