Next project: Western Air Patrol
#68
The IF transformer construction you mention, Ed, is typical of 1930s-1940s home radio IF transformers. Most 1939-1942 Philco IF transformers, with the exception of most Tropic models, are made in this fashion. Other manufacturers made IF transformers like this also.
Next project: Western Air Patrol - by EdHolland - 01-18-2018, 05:28 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 05:31 PM
RE: Next project: Western Air Patrol - by morzh - 01-18-2018, 11:55 PM
RE: Next project: Western Air Patrol - by Arran - 01-19-2018, 12:52 AM
RE: Next project: Western Air Patrol - by SteveG - 01-19-2018, 07:14 PM
RE: Next project: Western Air Patrol - by Arran - 01-23-2018, 01:11 AM
RE: Next project: Western Air Patrol - by David - 01-25-2018, 09:48 PM
RE: Next project: Western Air Patrol - by KCMike - 04-05-2020, 04:56 PM
RE: Next project: Western Air Patrol - by RodB - 04-20-2020, 08:51 PM
RE: Next project: Western Air Patrol - by RodB - 04-21-2020, 09:54 AM
RE: Next project: Western Air Patrol - by 462ron - 04-24-2020, 07:48 AM
RE: Next project: Western Air Patrol - by 462ron - 04-26-2020, 08:47 AM
RE: Next project: Western Air Patrol - by Ron Ramirez - 04-29-2020, 02:16 PM
Philco 91 Tuning Condenser
