Magnavox Regency Symphony, 1947?
#39
Now, there's a prewar Maggie Belvedere for sale nearby. I'd like to see about buying it, but right now, i have no way to get it home. I have a '96 Buick Roadmaster wagon, and the transmission is blown. I'd have had it to a guy to rebuild it, but this snow siege put everything to a stop.
The transmission will take a week, easily. the cause of the trans trouble was a blown-open transmission cooler tube. It dumped the fluid, just as I was approaching an exit on I-75, going 60 MPH. By the time I could get it off of the interstate, the third gear clutches were toast. There's new fluid in the thing now, and I can get first and second, but the clutches are gone for third.
I think that Ron has the same car. The cooler tubes are no longer available from GM. The car is actually a Chevy, with a Buick nameplate. There is an outfit here nearby, named Inline Tube. They will make new cooler tubes for me, when I take the old ones to them. Turnaround time is about a week There might be some way to buy the Magnaox and pick it up in a week or two. If I buy the set, I have no idea where I'd put it. I have a soft spot in my head for those prewar Magnavox sets. I alredy have a Regency-Symphony and Chairside, all from about 1941. Cabinets are similar, but the chassis are different. Re-capped, they are excellent performers, and comparable to the post war models. There was even a prewar Windsor, too, but I've never seen one in the flesh. My Windsor is around a '48 model. Those fine radios get to be a disease for a body.
Now, back to Inline Tube. They make brake line kits for many older model cars, both in galvanized and stainless steel. A couple of years ago, I bought a stainless kit for one of my '41 Cadillacs. It's on the car now, and the mechanic who installed it said that it could have come right from Cadillac parts. I have three more '41 Cadillac kits ordered, for the other three '41 Cadillacs that I have. In my life, I've had four brake lines get a pinhole from rust, and lost brakes. Never again, if I have any say in it!
If I do get the Belvedere, it'll be the second console for me in 6 months. The other one was the 37-650XP Philco.
So, with any luck, I might have another early Maggie. Call me nuts; I am.
Magnavox Regency Symphony, 1947? - by Ron Ramirez - 10-19-2010, 09:03 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:16 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 01:56 PM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:32 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-20-2010, 07:57 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-21-2010, 06:15 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-26-2010, 01:13 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-28-2010, 10:06 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 11-17-2010, 02:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-05-2010, 07:30 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-16-2010, 04:26 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 01-21-2011, 07:48 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 05:02 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 06:58 PM
Re: Magnavox Regency Symphony, 1947? - by Doug Houston - 02-04-2011, 01:38 AM
Re: Magnavox Regency Symphony, 1947? - by PFJC2 - 02-06-2011, 10:08 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-07-2011, 10:16 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 12:18 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:39 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:16 AM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:54 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-25-2011, 07:23 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-03-2011, 10:45 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 05:29 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 09:30 PM
Eico 232 VTVM Schematic
There are currently 6564 online users. [Complete List]
» 2 Member(s) | 6562 Guest(s)
