Poll: Which is the best US radio of all time? - You do not have permission to vote in this poll.
McMurdo Silver Masterpiece V
0%
0
0%
Scott Philharmonic
20.00%
2
20.00%
RCA C15-3
0%
0
0%
Philco 38-690
10.00%
1
10.00%
Scott Allwave 23
10.00%
1
10.00%
McMurdo Silver Masterpiece VI
10.00%
1
10.00%
Philco 37-690
0%
0
0%
RCA 15T
0%
0
0%
Zenith Stratosphere 1000Z
20.00%
2
20.00%
Crosley WLW
30.00%
3
30.00%
* You voted for this item. Show Results
Test poll
This reminds me of one of Shango066's YouTube Repair Videos where he worked on a 1934 Patterson All-Wave Radio that when he got done fixing it up he was doing a scan of the radio dial and he got to the upper end of the AM band (Police Band) around 1710 KC and there was an announcement that kept repeating itself saying "This is a test, This is a test, This is only a test!" with kind of a creepy sounding female voice and it kept repeating that messeage every 15 seconds, and Shango (I'm not sure what his real name is) basically was saying how eerie and creepy that message sounded because he thought it reminded him of those test messages that they used to put out on the old Civil Defense stations during the Cold War (640 and 1240 on the AM Band from the 1950s until the 1970s when the Emergency Broadcast System took its place).
And I even thought the announcement sounded creepy, and I never even lived through the Cold War like he did.
Test poll - by Ron Ramirez - 04-30-2020, 10:15 AM
RE: Test poll - by morzh - 04-30-2020, 10:27 AM
RE: Test poll - by Ron Ramirez - 04-30-2020, 10:39 AM
RE: Test poll - by Paul Philco322 - 04-30-2020, 06:59 PM
RE: Test poll - by morzh - 04-30-2020, 07:04 PM
RE: Test poll - by captainclock1988 - 05-01-2020, 12:30 PM
RE: Test poll - by Brad Winder - 05-05-2020, 10:08 AM
RE: Test poll - by PhilcoJohn - 05-07-2020, 08:40 AM
RE: Test poll - by morzh - 05-07-2020, 09:21 AM
Philco 91 Tuning Condenser
There are currently 10152 online users. [Complete List]
» 3 Member(s) | 10149 Guest(s)
