philco 84b in todays "world"
Good for you, when power fails and then with good battery set you get the same effect, nice sounds. Paul. Btw what's your 20? Location as the normal folk say.
philco 84b in todays "world" - by falcon123 - 05-04-2020, 08:22 AM
RE: philco 84b in todays "world" - by Paul Philco322 - 05-04-2020, 08:26 AM
RE: philco 84b in todays "world" - by falcon123 - 05-04-2020, 09:18 AM
RE: philco 84b in todays "world" - by falcon123 - 05-04-2020, 08:43 PM
Philco 91 Tuning Condenser
There are currently 5200 online users. [Complete List]
» 1 Member(s) | 5199 Guest(s)
