Heath-Zenith (Heathkit) Frequency Counter Model SM-2420
I got the frequency counter to work, using the tips you suggested, the only problem now is that the signal generator won't output a 400 Hz test tone and signal at the setting that the signal generator is set at, all I get is a buzzing noise out of the radio speaker and that's it.
RE: Heath-Zenith (Heathkit) Frequency Counter Model SM-2420 - by captainclock1988 - 05-04-2020, 10:00 PM
