Northern Electric Vimy console
I am curious as to how you are making out with the Northern Electric Vimy?
I have a Vimy and a Bombay. and they both perform good although on my Vimy I could not get one of the presets to work.
Dan in Caalgary
   Living in Calgary Alberta
Northern Electric Vimy console - by Brad Winder - 04-13-2020, 12:04 AM
RE: Northern Electric Vimy console - by EdHolland - 04-13-2020, 10:52 AM
RE: Northern Electric Vimy console - by RodB - 04-13-2020, 05:24 PM
RE: Northern Electric Vimy console - by EdHolland - 04-14-2020, 12:05 PM
RE: Northern Electric Vimy console - by Dan Walker - 05-05-2020, 06:42 PM
RE: Northern Electric Vimy console - by rfeenstra - 05-05-2020, 08:47 PM
Philco 91 Tuning Condenser
There are currently 10417 online users. [Complete List]
» 2 Member(s) | 10415 Guest(s)
