Heath-Zenith (Heathkit) Frequency Counter Model SM-2420
Quote:If you look at the schematic for the SG-8, there is a connection in the tank circuit of the RF OSC that has a common connection with the AF mod output tube, 6C4.  I'd be looking for a cold solder joint at that connection, or an error.
Hey Kim, I think I found the problem, take a look at the picture below and tell me what you think.
RE: Heath-Zenith (Heathkit) Frequency Counter Model SM-2420 - by captainclock1988 - 05-06-2020, 07:10 PM
Eico 232 VTVM Schematic
There are currently 3182 online users. [Complete List]
» 2 Member(s) | 3180 Guest(s)
